他のボードでも同じような現象があったと記憶していますが、エラーが発生しているようでマウントできないようです。
LinuxでCustom bootloader使えている方、いらっしゃいますか?
Linux jun-UX370UAR 4.15.0-76-generic #86-Ubuntu SMP Fri Jan 17 17:24:28 UTC 2020 x86_64 x86_64 x86_64 GNU/Linux
[13958.595258] usb 1-2.2.2: new high-speed USB device number 55 using xhci_hcd[13958.695876] usb 1-2.2.2: config 1 interface 0 altsetting 0 bulk endpoint 0x82 has invalid maxpacket 64[13958.695884] usb 1-2.2.2: config 1 interface 0 altsetting 0 bulk endpoint 0x2 has invalid maxpacket 64[13958.696540] usb 1-2.2.2: New USB device found, idVendor=0703, idProduct=0104[13958.696548] usb 1-2.2.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3[13958.696553] usb 1-2.2.2: Product: Mbed MSD[13958.696558] usb 1-2.2.2: Manufacturer: mbed.org[13958.696563] usb 1-2.2.2: SerialNumber: 0123456789[13958.697800] usb-storage 1-2.2.2:1.0: USB Mass Storage device detected[13958.698381] scsi host5: usb-storage 1-2.2.2:1.0[13959.715105] scsi 5:0:0:0: Direct-Access MBED.ORG MBED USB DISK 1.0 PQ: 0 ANSI: 0 CCS[13959.715442] sd 5:0:0:0: Attached scsi generic sg4 type 0[13959.715562] sd 5:0:0:0: [sde] 4079 4096-byte logical blocks: (16.7 MB/15.9 MiB)[13959.715679] sd 5:0:0:0: [sde] Write Protect is off[13959.715681] sd 5:0:0:0: [sde] Mode Sense: 03 00 00 00[13959.715802] sd 5:0:0:0: [sde] No Caching mode page found[13959.715804] sd 5:0:0:0: [sde] Assuming drive cache: write through[13959.795023] usb 1-2.2.2: reset high-speed USB device number 55 using xhci_hcd[13959.991062] usb 1-2.2.2: reset high-speed USB device number 55 using xhci_hcd[13960.187012] usb 1-2.2.2: reset high-speed USB device number 55 using xhci_hcd[13960.391066] usb 1-2.2.2: reset high-speed USB device number 55 using xhci_hcd[13960.587057] usb 1-2.2.2: reset high-speed USB device number 55 using xhci_hcd[13960.783035] usb 1-2.2.2: reset high-speed USB device number 55 using xhci_hcd[13960.883923] sd 5:0:0:0: [sde] Unaligned partial completion (resid=4032, sector_sz=4096)[13960.883937] sd 5:0:0:0: [sde] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK[13960.883943] sd 5:0:0:0: [sde] tag#0 CDB: Read(10) 28 00 00 00 00 00 00 00 01 00[13960.883947] print_req_error: I/O error, dev sde, sector 0[13960.883958] Buffer I/O error on dev sde, logical block 0, async page read[13960.963141] usb 1-2.2.2: reset high-speed USB device number 55 using xhci_hcd[13961.163050] usb 1-2.2.2: reset high-speed USB device number 55 using xhci_hcd[13961.358954] usb 1-2.2.2: reset high-speed USB device number 55 using xhci_hcd[13961.558984] usb 1-2.2.2: reset high-speed USB device number 55 using xhci_hcd[13961.755044] usb 1-2.2.2: reset high-speed USB device number 55 using xhci_hcd[13961.959383] usb 1-2.2.2: reset high-speed USB device number 55 using xhci_hcd[13962.064041] sd 5:0:0:0: [sde] Unaligned partial completion (resid=4032, sector_sz=4096)[13962.064055] sd 5:0:0:0: [sde] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK[13962.064060] sd 5:0:0:0: [sde] tag#0 CDB: Read(10) 28 00 00 00 00 00 00 00 01 00[13962.064064] print_req_error: I/O error, dev sde, sector 0[13962.064075] Buffer I/O error on dev sde, logical block 0, async page read
