LCDに全画面表示したいのですが、サンプルプログラムの修正方法を教えてください。よろしくお願いします。
http://gadget.renesas.com/ja/product/lychee_sp/8.html
をLCD表示にして全画面表示にしたいのです。
全画面が無理なら中央表示でも結構です。
開発環境はide4grです。
とりあえず作りかけたのですが、この先に進めていません。
// GR-LYCHEE OpenCV finger count example.// Referred :// github.com/.../ElAlgilaV2.cpp#include <Arduino.h>#include <Camera.h>//#include <DisplayApp.h>#include <opencv.hpp>#include <LCD.h>
#define LCD_IMAGE_HW 480#define LCD_IMAGE_VW 272
using namespace cv;#define IMAGE_HW 320#define IMAGE_VW 240//#define IMAGE_HW 480//#define IMAGE_VW 272// 1MB of NC_BSS is not used for malloc function.// It's better to secure buffer as a static memory in this NC_BSSuint8_t bgr_buf[3 * IMAGE_HW * IMAGE_VW]__attribute((section("NC_BSS"),aligned(32)));uint8_t hsv_buf[3 * IMAGE_HW * IMAGE_VW]__attribute((section("NC_BSS"),aligned(32)));uint8_t syn_buf[3 * IMAGE_HW * IMAGE_VW]__attribute((section("NC_BSS"),aligned(32))); Camera camera(IMAGE_HW, IMAGE_VW);//DisplayApp display_app;LCD lcd(LCD_IMAGE_HW, LCD_IMAGE_VW);static uint8_t lcd_buf[LCD_IMAGE_HW * LCD_IMAGE_VW * 2]; // 2 bytes per pixel
bool g_mode = false; void setup() { camera.begin(); lcd.begin(lcd_buf, IMAGE_HW, IMAGE_VW); //lcd.begin(lcd_buf, LCD_IMAGE_HW, LCD_IMAGE_VW); lcd.clear(); delay(100);} void loop() { static unsigned long last_time = 0; if((millis() - last_time) > 2000){ g_mode = !g_mode; last_time = millis(); } Mat img_raw(IMAGE_VW, IMAGE_HW, CV_8UC2, camera.getImageAdr()); Mat img_bgr(IMAGE_VW, IMAGE_HW, CV_8UC3, bgr_buf); cvtColor(img_raw, img_bgr, COLOR_YUV2BGR_YUYV); // copy camera image to img_bgr Mat img_hsv(IMAGE_VW, IMAGE_HW, CV_8UC3, hsv_buf); cvtColor(img_bgr, img_hsv, COLOR_BGR2HSV); Mat img_temp, img_mask; inRange(img_hsv, Scalar(0, 50, 50), Scalar(20, 255, 255), img_temp); inRange(img_hsv, Scalar(160, 50, 50), Scalar(180, 255, 255), img_mask); img_mask = img_mask + img_temp; // medianBlur(img_mask, img_mask, 3); // cut noise GaussianBlur(img_mask, img_mask, Size(27, 27), 3.5, 3.5); threshold(img_mask, img_mask, 140, 255, 0); // mask processing for drawing a picture //Mat img_synthesis(IMAGE_VW, IMAGE_HW, CV_8UC3, syn_buf); Mat img_synthesis(LCD_IMAGE_VW, LCD_IMAGE_HW, CV_8UC3, syn_buf); img_synthesis = Scalar(0, 0, 0); // find contours vector<vector<Point> > contours; vector<Vec4i> hierarchy; findContours(img_mask, contours, hierarchy, RETR_EXTERNAL, CHAIN_APPROX_NONE); int fingerCount = 0; if (contours.size() > 0){ size_t indexOfBiggestContour = -1; size_t sizeOfBiggestContour = 0; for (size_t i = 0; i < contours.size(); i++){ if (contours[i].size() > sizeOfBiggestContour){ sizeOfBiggestContour = contours[i].size(); indexOfBiggestContour = i; } } vector<vector<int> >hull(contours.size()); vector<vector<Point> >hullPoint(contours.size()); //elin hareketine gテカre eli テァevreleyen テァokgen vector<vector<Vec4i> > defects(contours.size()); //parmak uclarindaki yesil noktalar..multi dimensional matrix vector<vector<Point> >defectPoint(contours.size()); //point olarak parmak ucu noktalarテスnテス x,y olarak tutuyor vector<vector<Point> >contours_poly(contours.size()); //eli テァevreleyen hareketli dikdテカrtgen Point2f rect_point[4]; vector<RotatedRect>minRect(contours.size()); vector<Rect> boundRect(contours.size()); for (size_t i = 0; i<contours.size(); i++){ if (contourArea(contours[i])>5000){ convexHull(contours[i], hull[i], true); convexityDefects(contours[i], hull[i], defects[i]); if (indexOfBiggestContour == i){ minRect[i] = minAreaRect(contours[i]); for (size_t k = 0; k<hull[i].size(); k++){ int ind = hull[i][k]; hullPoint[i].push_back(contours[i][ind]); } for (size_t k = 0; k<defects[i].size(); k++){ if (defects[i][k][3]>13 * 256){ int p_start = defects[i][k][0]; int p_end = defects[i][k][1]; int p_far = defects[i][k][2]; defectPoint[i].push_back(contours[i][p_far]); circle(img_synthesis, contours[i][p_end], 3, Scalar(0, 255, 0), 2); //i ydi fingerCount++; } } drawContours(img_synthesis, contours, i, Scalar(255, 255, 0), 2, 8, vector<Vec4i>(), 0, Point()); drawContours(img_synthesis, hullPoint, i, Scalar(255, 255, 0), 1, 8, vector<Vec4i>(), 0, Point()); drawContours(img_mask, hullPoint, i, Scalar(0, 0, 255), 2, 8, vector<Vec4i>(), 0, Point()); approxPolyDP(contours[i], contours_poly[i], 3, false); boundRect[i] = boundingRect(contours_poly[i]); rectangle(img_mask, boundRect[i].tl(), boundRect[i].br(), Scalar(255, 0, 0), 2, 8, 0); minRect[i].points(rect_point); for (size_t k = 0; k<4; k++){ line(img_mask, rect_point[k], rect_point[(k + 1) % 4], Scalar(0, 255, 0), 2, 8); } } } } } if(g_mode){ img_mask = Scalar(255); }// for showing original image img_bgr.copyTo(img_synthesis, img_mask); // draw text stringstream ss; ss << "Finger Count: " << fingerCount; putText(img_synthesis, ss.str(), Point(5, img_synthesis.rows - 8), FONT_HERSHEY_DUPLEX, 0.5, Scalar(255, 255, 255), 1); // display image size_t jpegSize = camera.createJpeg(IMAGE_HW, IMAGE_VW, img_synthesis.data, Camera::FORMAT_RGB888);// display_app.SendJpeg(camera.getJpegAdr(), jpegSize); lcd.BGR2YUV(img_synthesis.data, lcd_buf, LCD_IMAGE_HW, LCD_IMAGE_VW); //lcd.BGR2YUV(img_synthesis.data, lcd_buf, IMAGE_HW, IMAGE_VW); delay(10);}
