关于drp库中dilate和erode结构元大小问题
工程师们好,
         想问下能不能更换drp库函数中的结构元大小,默认3*3的有点太小了,多进行几次的话时延有点长,还是说不能修改只能用opencv去实现了
  • 目前这两个库的参数是固定死的不能修改。只能多做几次,例如:
    void R_BCD_DRP_Dilate(uint32_t input_address, uint32_t output_address1, uint32_t output_address2, uint32_t input_width, uint32_t input_height, uint8_t times)
       int32_t ret_val;
       uint32_t tile_no;
       uint8_t loop;
       if(times == 0)
        return;
    /* Load DRP Library       */
    /* tile 0 |   Dilate    | */
    /* tile 1 |   Dilate    | */
    /* tile 2 |   Dilate    | */
    /* tile 3 |   Dilate    | */
    /* tile 4 |   Dilate    | */
    /* tile 5 |   Dilate    | */
    PerformSetStartTime(TIME_DILATE_DL);
    ret_val = R_DK2_Load(&g_drp_lib_dilate[0],
    R_DK2_TILE_0 | R_DK2_TILE_1 | R_DK2_TILE_2 | R_DK2_TILE_3 | R_DK2_TILE_4 | R_DK2_TILE_5,
    R_DK2_TILE_PATTERN_1_1_1_1_1_1, NULL, &cb_drp_finish, &drp_lib_id[0]);
    //DRP_DRV_ASSERT(ret_val);
    /* Activate DRP Library */
    ret_val = R_DK2_Activate(drp_lib_id[TILE_0] | drp_lib_id[TILE_1] | drp_lib_id[TILE_2] |
    drp_lib_id[TILE_3] | drp_lib_id[TILE_4] | drp_lib_id[TILE_5], 0);
    /* Set end time of process(DL)*/
    PerformSetEndTime(TIME_DILATE_DL);
    /* Set start time of process*/
    PerformSetStartTime(TIME_DILATE_EXE);
    /* Set R_DK2_Start function parameters */
    for (loop =0; loop < times; loop++){
    for (tile_no = 0; tile_no < R_DK2_TILE_NUM; tile_no++)
    if(loop == 0)
    /* Set the address of buffer to be read/write by DRP */
    param_dilate[tile_no].src = input_address  + (input_width * (input_height / R_DK2_TILE_NUM)) * tile_no;
    param_dilate[tile_no].dst = output_address1 + (input_width * (input_height / R_DK2_TILE_NUM)) * tile_no;
    else
    if (loop%2 == 1)
    param_dilate[tile_no].src = output_address1  + (input_width * (input_height / R_DK2_TILE_NUM)) * tile_no;
    param_dilate[tile_no].dst = output_address2 + (input_width * (input_height / R_DK2_TILE_NUM)) * tile_no;
    else
    param_dilate[tile_no].src = output_address2  + (input_width * (input_height / R_DK2_TILE_NUM)) * tile_no;
    /* Set Image size */
    param_dilate[tile_no].width  = (uint16_t)input_width;
    param_dilate[tile_no].height = (uint16_t)input_height / R_DK2_TILE_NUM;
    /* Set whether to perform top or bottom edge border processing. */
    param_dilate[tile_no].top    = (tile_no == TILE_0) ? 1 : 0;
    param_dilate[tile_no].bottom = (tile_no == TILE_5) ? 1 : 0;
    /* Initialize variables to be used in termination judgment of the DRP library */
    drp_lib_status[tile_no] = DRP_NOT_FINISH;
    /* Start DRP Library */
    ret_val = R_DK2_Start(drp_lib_id[tile_no], (void *)&param_dilate[tile_no], sizeof(r_drp_dilate_t));
    /* Wait until DRP processing is finish */
    while (drp_lib_status[tile_no] == DRP_NOT_FINISH);
       /* Set end time of process */
       PerformSetEndTime(TIME_DILATE_EXE);
       /* Unload DRP library */
       ret_val = R_DK2_Unload(drp_lib_id[TILE_0] | drp_lib_id[TILE_1] | drp_lib_id[TILE_2] |
        drp_lib_id[TILE_3] | drp_lib_id[TILE_4] | drp_lib_id[TILE_5], &drp_lib_id[TILE_0]);
